Bobbedmanche92 Posted May 17, 2021 Share Posted May 17, 2021 Started Life as a 2.8 auto 4wd. Now 4.0 6 speed 4wd from an 05 LJ. 86 J20 axles and tons of custom mods. Will do some write ups here then. Link to comment Share on other sites More sharing options...
Jesse J Posted May 17, 2021 Share Posted May 17, 2021 dig it looks great. what's going on with the bed I see it's bobbed but is there another fuel thing? Link to comment Share on other sites More sharing options...
Bobbedmanche92 Posted May 17, 2021 Author Share Posted May 17, 2021 Fuel door was filled in and welded the fuel door section in out of the donor XJ. Used some of the inner structure from the XJ as well. Oh yeah, custom gas tank skid for the 97-01 XJ tank relocated to the rear.. lol Link to comment Share on other sites More sharing options...
eaglescout526 Posted May 17, 2021 Share Posted May 17, 2021 *ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT -ZZ AJT RADIO PREP GROUP AJY Popular Equipment Package CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DGF H D A904 AUTO TRANS EFB ENGINE - 2.8L GM 6CYL GAC ALL WINDOWS - TINTED GLASS GEC Window - Left Side, Front, Sliding GSC MIRROR - RIGHT BLACK HCC HEATER W/UPR LEVEL VENTIL - TYPE II JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MLDGS - VINYL LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED MFD BRIGHT GRILLE - TYPE I NAA ESA W/CATALYST (EXC CALIF SYSTEM) NFA TANK - 23 GAL FUEL SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE Build date 8/20/85 Body code JM62 Link to comment Share on other sites More sharing options...
Bobbedmanche92 Posted May 18, 2021 Author Share Posted May 18, 2021 Thanks eaglescout! All three of the trucks you did for me yesterday seem about as base as base get haha. Do some trucks not have the info of the original dealership sold? Link to comment Share on other sites More sharing options...
eaglescout526 Posted May 18, 2021 Share Posted May 18, 2021 2 hours ago, Bobbedmanche92 said: Thanks eaglescout! All three of the trucks you did for me yesterday seem about as base as base get haha. Do some trucks not have the info of the original dealership sold? It seems that only the 84-86 AMC years lack the info as to where they were sold which is unfortunate but we will take what we can get. Link to comment Share on other sites More sharing options...
Jesse J Posted May 18, 2021 Share Posted May 18, 2021 On 5/16/2021 at 9:50 PM, Bobbedmanche92 said: Fuel door was filled in and welded the fuel door section in out of the donor XJ. Used some of the inner structure from the XJ as well. Oh yeah, custom gas tank skid for the 97-01 XJ tank relocated to the rear.. lol that's pretty sweet. definetely saving the fuel stuff out of an xj if I choose too. did the tank just fit? no frame rail cutting? Link to comment Share on other sites More sharing options...
Bobbedmanche92 Posted May 18, 2021 Author Share Posted May 18, 2021 eaglescout526 that's fair, seems like typical AMC things . Thank you for the info though! Jesse J I just welded drilled and welded studs to mount my custom skid. 97-01 tank housed in my skid and straps I made bolt to the skid to hold the tank inside of it. I can post more pics or send you some if you need then. No cutting of the frame was necessary. All of the fuel lines were good on my donor XJ so i swapped them over, spliced in a section and it all worked well and was fairly simple. I've had alot of XJs and on Manche #5 now but never had to mess with Renix fuel stuff. Fuel pump is bad/not working in my newest purchase. Gonna see if I can figure it out with Crusier54's tips... Link to comment Share on other sites More sharing options...
