BombDoc Posted April 25, 2021 Share Posted April 25, 2021 1988 Jeep Comanche Pioneer 4.0L engine, 5 speed manual, short wheel base, RWD, bucket seats Build date is unavailable, the sticker is completely bleached out Current Location: W Texas Status: On the road...somehow! I put some notes below. Synchro for reverse is suspected to be done-for, but it does reverse if you hold it there, and the lights and everything work well enough to be on the road. Wiring harnesses are chopped up bad and need to be replaced. Notes: This MJ was used as a farm truck for many years, so it has all the typical things you'd find on a farm truck...weird wiring, chopped up and spliced wiring and connections, switches that don't work, added switches to bypass the inoperable ones; rigged-up "fixes" to broken things, pretty much no money spent to fix anything right, just whatever kept it working. Interesting is that apart from a bad weld/repair on the door striker, there is ZERO RUST anywhere. Not the floors, not the shelf behind the rear wheels, nothing. The body is banged up a bit and the rear bumper is probably the worst of it, but it runs and drives without any showstopping issues. Link to comment Share on other sites More sharing options...
89 MJ Posted April 26, 2021 Share Posted April 26, 2021 Seems like a great fixer upper! Link to comment Share on other sites More sharing options...
eaglescout526 Posted April 26, 2021 Share Posted April 26, 2021 *X8 SEATS - CLOTH LOW-BACK BUCKET -H9 3LY AGJ Driver Assistance Group APA MONOTONE PAINT PACKAGE BCQ Battery - Maintenance Free CAC BUCKET SEAT - LO BK CGW CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DDJ 5SPD MANUAL TRANS ERB ENGINE - 4.0L I6 MPI GAS GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GSC MIRROR - RIGHT BLACK HAA AIR CONDITIONING - FRONT JFH TACHOMETER - MECH JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MOLDINGS - VINYL LAP FUEL ECONOMY SHIFT INDICATOR LIGHT LMA HALOGEN HEADLAMPS MBJ Bumper - Front, Black NAA ESA W/CATALYST (EXC CALIF SYSTEM) NHQ Transmission Heater PX6 QX6 RAF Radio - AM/FM Cassette SBA POWER STEERING SCE STRG WHL - EURO/SPORT TYPE SUA TILT STEERING COLUMN TBG SPARE TIRE - COMPACT WJD WHEELS - 15 X 7.0 STYLED STEEL Build date 9/2/87 Body code TM61 Sold by FOWLER JEEP EAGLE, NORMAN OK Link to comment Share on other sites More sharing options...
BombDoc Posted April 26, 2021 Author Share Posted April 26, 2021 Awesome, thanks guys! Link to comment Share on other sites More sharing options...
