Speed Unit Posted March 15, 2021 Share Posted March 15, 2021 Have column shifter MJ. Attempting to remove the gauge cluster, it is free except for a small cable the comes from the bottom middle. I think it runs in to the steering column. Need to detach it. Any ideas where it goes in the column? Any advice on how to get to it? Link to comment Share on other sites More sharing options...
scaleless Posted March 15, 2021 Share Posted March 15, 2021 If it's the same as my '87 (and assuming I can remember correctly since it no longer has an automatic), it connects to the top of the plastic housing that rotates with the shift lever. It just clips on. Pretty sure that's how it was, but it's been a long time since I pulled it off so take that with a grain of salt. I'll get a pic in the morning if nobody beats me to it. Link to comment Share on other sites More sharing options...
Minuit Posted March 15, 2021 Share Posted March 15, 2021 @scaleless is correct. It clips on to the outside of the column. Link to comment Share on other sites More sharing options...
CGCWO Posted March 15, 2021 Share Posted March 15, 2021 16 hours ago, Minuit said: @scaleless is correct. It clips on to the outside of the column. Ditto!!!! Link to comment Share on other sites More sharing options...
