shagtn Posted March 22, 2006 Share Posted March 22, 2006 When I picked up my MJ in January the hose coming from the PCV was basicly just laying on top of the engine and would start spitting oil out as the engine warmed up. I Ran this hose straight to the Air Filter housing as a Temp fix and this past weekend I removed the hose and replaced it with a new rubber grommet and a breather filter and capped off the hole on the back side of the air filter. I am curious if there is anything that I have over looked as I do not want to cause more harm than good with this setup. Thanks, -Will Link to comment Share on other sites More sharing options...
Bounty Hunter Posted March 22, 2006 Share Posted March 22, 2006 Make sure this hole has vacuum sucking into the crankcase, otherwise your CCV system is not working correctly. The vacuum line at the rear of the valve cover should suck into the intake manifold, and the valve cover will draw air in through the front line to the intake, or as you have, a filter. Link to comment Share on other sites More sharing options...
Eagle Posted March 23, 2006 Share Posted March 23, 2006 The '88 4.0L does not have a PCV. Which hose are you referring to, the large one at the front of the valve cover or the small one at the rear of the valve cover? Link to comment Share on other sites More sharing options...
shagtn Posted March 23, 2006 Author Share Posted March 23, 2006 I am talking about the large one at the front of the cover. If it is not PCV, then what is it called?\ -Will Link to comment Share on other sites More sharing options...
tjbliley Posted March 23, 2006 Share Posted March 23, 2006 Its called a CCV or Crank Case Ventilation. it is just air flow without a valve or restriction. Link to comment Share on other sites More sharing options...
shagtn Posted March 23, 2006 Author Share Posted March 23, 2006 Thanks, I will get some pics this afternoon when I get home and see if the current setup is sufficient. Link to comment Share on other sites More sharing options...
512tr Posted March 24, 2006 Share Posted March 24, 2006 Here is a good overview over the stock Renix vacuum/air system Link to comment Share on other sites More sharing options...
87manche Posted March 24, 2006 Share Posted March 24, 2006 awesome diagram,. Link to comment Share on other sites More sharing options...
