Dana 30 with no differential innards
Eff. I'll probably pick up an actual 2wd straight axle for it. I just realized I pulled all the brakes off my old 4wd axle, and it's rear brakes that I don't want, not front. Can't do smokey burnouts with only rear brakes.
But I'm still curious for an answer.
If you only leave the outter shafts you should be ok. You need them to hold the integrity of the unit bearing. But you would not be able to do this with the inner shafts attached, because they would flop around destroy themselves/the housing with nothing for them to ride in.
Like you said, you would be better of with a 2wd straight axle. I don't see why the brakes wouldn't work though. I have driven sans inner shaft on my driver's side with no affect to braking.
I've got the 2WD beam axle from my MJ sitting up near Pittsburgh, PA. You can have it for free......you just have to come pick it up :D
Jeff
:cheers:
The problem with the brakes was that they are on my MJ, so I'd have to buy all new braking components for the rat.
The outer axle shafts won't bounce around at all?
