CGCWO Posted February 14, 2021 Share Posted February 14, 2021 IMG_3675.MOV So I was able to get Little Blue (87 4.0 renix 4x4 auto) to run. Bypassed fuel pump relay after replacing all the fuel line connections, fuel pressure regulator and basically a completely new fuel system from tank to injectors. Now I need to figure out why the relay isn’t working correctly. I have tried several new supposedly hood relays and the only thing that works is using a jumper on the relay. Any suggestions or thoughts as where to look? Link to comment Share on other sites More sharing options...
Ωhm Posted February 14, 2021 Share Posted February 14, 2021 Is D1_5 Hot (B+) at all times? Link to comment Share on other sites More sharing options...
CGCWO Posted February 15, 2021 Author Share Posted February 15, 2021 20 hours ago, Ωhm said: Is D1_5 Hot (B+) at all times? D1_5 Link to comment Share on other sites More sharing options...
Ωhm Posted February 15, 2021 Share Posted February 15, 2021 Need to do a visual inspection of your fusible links located on the starter relay. Look for bubbles, holes, open wire. If fusible links look good, track back wire at D1_5 to its splice in the harness. Link to comment Share on other sites More sharing options...
CGCWO Posted February 15, 2021 Author Share Posted February 15, 2021 15 minutes ago, Ωhm said: Need to do a visual inspection of your fusible links located on the starter relay. Look for bubbles, holes, open wire. If fusible links look good, track back wire at D1_5 to its splice in the harness. Thanks. Working on that, between tornado warnings/watches. I am ready for spring/summer. Link to comment Share on other sites More sharing options...
Ωhm Posted February 15, 2021 Share Posted February 15, 2021 On a precautionary note, the way you jumped the Fuel Pump Relay Block, Fuel Pump Motor, Injectors and a few other components are now running current flow through the Ignition Switch (I1 feed). Could possibly overheat the IGN SW. Link to comment Share on other sites More sharing options...
CGCWO Posted February 15, 2021 Author Share Posted February 15, 2021 1 hour ago, Ωhm said: Need to do a visual inspection of your fusible links located on the starter relay. Look for bubbles, holes, open wire. If fusible links look good, track back wire at D1_5 to its splice in the harness. Think I’ve found the issue. Non-existing splice on D1_5 Link to comment Share on other sites More sharing options...
CGCWO Posted February 15, 2021 Author Share Posted February 15, 2021 2 minutes ago, Ωhm said: On a precautionary note, the way you jumped the Fuel Pump Relay Block, Fuel Pump Motor, Injectors and a few other components are now running current flow through the Ignition Switch (I1 feed). Could possibly overheat the IGN SW. I kind of figured that. So I’ve only run it like that for a few minutes. Just verify it will run and idle, kind of that is. Link to comment Share on other sites More sharing options...
Ωhm Posted February 15, 2021 Share Posted February 15, 2021 1 minute ago, CGCWO said: I kind of figured that. So I’ve only run it like that for a few minutes. Just verify it will run and idle, kind of that is. Link to comment Share on other sites More sharing options...
Ωhm Posted February 15, 2021 Share Posted February 15, 2021 Splice_E is HOT (B+) from the Fusible LInk G. Splice_E also feed B+ to the Fuel Pump Relay C216_1 (30). Link to comment Share on other sites More sharing options...
CGCWO Posted February 15, 2021 Author Share Posted February 15, 2021 She started right up, not a steady idle but the splice was the fuel pump/pressure issue. Idles up then almost dies, but comes back to life. IMG_3691.MOV Link to comment Share on other sites More sharing options...
CGCWO Posted February 16, 2021 Author Share Posted February 16, 2021 @Ωhm thank you again for all the help! Link to comment Share on other sites More sharing options...
Ωhm Posted February 16, 2021 Share Posted February 16, 2021 Link to comment Share on other sites More sharing options...
