j_gevans Posted February 13, 2021 Share Posted February 13, 2021 Looking for some help with this issue. So I had all the light systems working fine about 9 months ago but then had the truck up on jacks for the rest of the time while working on some axle issues. Now that I got it all back together I'm having issues with the driver side turn signal. So when the headlights are off, the driver side, passenger side, and hazard lights all work fine. When the headlights are on, the passenger side and hazard lights work fine. When I turn the headlights on, the left turn signal indicator illuminates on the dash and is solid. When I turn on the left turn signal, it stays solid and the front and rear signals don't flash. When I turn the hazards on, the signal indicator flashes and the front and rear lights flash light they're supposed to. Just hoping someone might be able to help. I checked the fuses and swapped some and that didn't do anything. Link to comment Share on other sites More sharing options...
eaglescout526 Posted February 13, 2021 Share Posted February 13, 2021 Check the socket ground in the socket. They love to rust away into nothing cause they are a cheap metal. For some bizarre but probably money saving reason, AMC went from the good metal sockets of 84-86 to Ford sockets for 87-90. 91-96 changed back to the old style sockets. It’s best to replace both those front sockets now and never have to do worry about them not functioning again. Link to comment Share on other sites More sharing options...
j_gevans Posted February 13, 2021 Author Share Posted February 13, 2021 6 minutes ago, eaglescout526 said: Check the socket ground in the socket. They love to rust away into nothing cause they are a cheap metal. For some bizarre but probably money saving reason, AMC went from the good metal sockets of 84-86 to Ford sockets for 87-90. 91-96 changed back to the old style sockets. It’s best to replace both those front sockets now and never have to do worry about them not functioning again. Where is the socket ground you're talking about? Link to comment Share on other sites More sharing options...
jdog Posted February 13, 2021 Share Posted February 13, 2021 in the turn signal socket itself( the thing the bulb goes into) Link to comment Share on other sites More sharing options...
j_gevans Posted February 13, 2021 Author Share Posted February 13, 2021 Ok thanks for the help. The whole front light socket was bad and must of been causing some sort of short when the headlights turned on. I swapped it out with a spare I had and it works fine. Link to comment Share on other sites More sharing options...
jdog Posted February 14, 2021 Share Posted February 14, 2021 glad to hear you got it fixed, yeah they are pretty common to go out Link to comment Share on other sites More sharing options...
