Dickinson County Comanche Posted February 12, 2021 Share Posted February 12, 2021 Hello all, I was wondering what it would take to install a factory aux electrical fan on my non-A/C equipped Comanche. Are all the wires there for the install? I know I’ll need a temp. switch for the fan to kick on, and the fan itself, but I was curious if I need to find that piece of harness to make it all work. Thanks! -DCC Link to comment Share on other sites More sharing options...
jdog Posted February 12, 2021 Share Posted February 12, 2021 the wires are not there, they are a seperate a/c harness. you can make a harness, just be sure to put a relay and a fuse in it Link to comment Share on other sites More sharing options...
AZJeff Posted February 12, 2021 Share Posted February 12, 2021 I am not familiar with the cooling fan wiring on the older XJ/MJ series. From what I can determine looking at wiring diagrams, the ECU controls power to the electric cooling fan motor via fan clutch relay. I am assuming that the ECU uses the engine temperature sensor (and the heater control switch set to "A/C") to turn the fan relay on/off. If one is going to add in an electric cooling fan option without the A/C, the trick will be to find a way to sense engine temperature and power up the fan outside the normal ECU control method, since I don't think you can tap into that practically. I did this on an old F-150 truck by adding in a temperature switch into the upper radiator hose. When the coolant got hot enough, the switch closed, and that turned on the relay that powered the fan. Link to comment Share on other sites More sharing options...
DesertRat1991 Posted February 12, 2021 Share Posted February 12, 2021 This is a plug & play installation on the 91+ trucks. All connectors are present in the harness and no extra sensors required. Without A/C, the aux fan activates around 230deg and shuts off at 210deg. IMO, these trucks should have never left the factory without an aux fan. Link to comment Share on other sites More sharing options...
jdog Posted February 13, 2021 Share Posted February 13, 2021 43 minutes ago, DesertRat1991 said: hese trucks should have never left the factory without an aux fan. I agree with that one, i will be sitting in the drive thru awaiting food and truck will start to get hot. To install a fan and sensor is possible, just depends if you can find the a/c harness or if you just want to make one up. Link to comment Share on other sites More sharing options...
AZJeff Posted February 15, 2021 Share Posted February 15, 2021 On 2/12/2021 at 4:33 PM, DesertRat1991 said: This is a plug & play installation on the 91+ trucks. All connectors are present in the harness and no extra sensors required. Without A/C, the aux fan activates around 230deg and shuts off at 210deg. IMO, these trucks should have never left the factory without an aux fan. I totally agree that all MJ/XJ vehicles should have had an electric fan, regardless of whether A/C was present. that said, the OP’s truck is an 89, so his installation won’t be plug and play. He will have to devise a setup like I described, using a temp sensor independent of the one used by the ECU. Link to comment Share on other sites More sharing options...
