You can get repro brackets from Brandon aka krustyballer I believe is his user name on here.
Seats from a two door XJ are the ones you want..
84-95 XJ seats with the straight slider will bolt right to the Comanche's floor brackets. :L:  MJ buckets and MJ benches have the same floor brackets.
seats with the curved slider will also bolt on, but will raise you up a couple inches.
5 hours ago, Michael Frantzén said:
Thank´s : ))
when it comes down to it, most any bucket seat can work for you with a little 1x1 square tubing to make an adapter.  don't feel that you're limited to MJ/XJ stuff. :L:
