89 MJ Posted January 25, 2021 Share Posted January 25, 2021 Ok guys, either I'm a little stupid, or I am unlucky. I have 2 trucks with clocks. Neither of the clocks work. To be fair, I haven't checked to see if they are actually plugged in or not, but I just want to make sure that there isn't a way to turn them on. Is there a way to fix the clock if they are broken and don't show the time? Link to comment Share on other sites More sharing options...
87MJTIM Posted January 25, 2021 Share Posted January 25, 2021 My clock used to not display and/or the display was very dim. When it did display, it kept accurate time. I performed a dash ground upgrade. See Cruiser's Renix Tips #18. Once I installed the ground wire, it displays strong and bright. It worked for me. If you haven't done the upgrade, I recommend you do it first. Link to comment Share on other sites More sharing options...
89 MJ Posted January 25, 2021 Author Share Posted January 25, 2021 7 minutes ago, 87MJTIM said: My clock used to not display and/or the display was very dim. When it did display, it kept accurate time. I performed a dash ground upgrade. See Cruiser's Renix Tips #18. Once I installed the ground wire, it displays strong and bright. It worked for me. If you haven't done the upgrade, I recommend you do it first. Thanks, its not in my nice truck yet, so I haven't done the ground upgrades yet. Link to comment Share on other sites More sharing options...
