ogjeep Posted January 25, 2021 Share Posted January 25, 2021 Anyone know all the little bits ill need for this swap. I am losing the ba10 from my street comanche and sourced a 2wd ax15. I read through some threads but it was all 4x4 related. Thanks in advance Link to comment Share on other sites More sharing options...
Fernando87mj Posted January 25, 2021 Share Posted January 25, 2021 Depends.. is your Ax15 External or internal slave cylinder ? Link to comment Share on other sites More sharing options...
89 MJ Posted January 25, 2021 Share Posted January 25, 2021 This should cover the list of parts that you will need if doing an EXTERNAL SLAVE AX-15. Just ditch the transfer case part. Link to comment Share on other sites More sharing options...
ogjeep Posted January 28, 2021 Author Share Posted January 28, 2021 @Torq_Shep which one is it? Link to comment Share on other sites More sharing options...
89 MJ Posted January 28, 2021 Share Posted January 28, 2021 Regardless of whether or not it is external or internal slave, I would think you would use the AX-15 clutch and stuff, but use a Renix era flywheel. I ordered a flywheel for a 90 with a 5 speed because I knew the clutch stuff would work with it and the flywheel would work correctly with the CPS. Link to comment Share on other sites More sharing options...
Torq_Shep Posted January 28, 2021 Share Posted January 28, 2021 4 hours ago, ogjeep said: @Torq_Shep which one is it? It is an internal slave bell housing. It could easily be changed to external slave. Link to comment Share on other sites More sharing options...
