fuel pump
You should have a 16 or 23 gallon tank, can you confirm? Either way, yes, you can just replace the pump if it's bad. No need to replace the whole sending unit if it's in decent shape. For the 4.0, a Carter P90011 is a perfect fit and the kit comes with all the needed parts. A lot of the replacement fuel pumps are much shorter than the OE unit and you have to mod them to stay firmly in place.
no clue how many gallons my tank is, I'm going to make a guess and say it's 16 gallons. where would you recommend I get the Carter P90011 kit?
When you fill it up, how many gallons does it take?  That would indicate the tank size.
