JeepDew Posted November 3, 2007 Share Posted November 3, 2007 since my MJ has the pugoet tranny, and I am putting in an NV3550, is the pilot bushing the same. if not, do I use the pilot bushing for the pugoet or the NV. I remember a long time ago, do a sway on a YJ, but can't remember which bushing I used. thanks mike Link to comment Share on other sites More sharing options...
Pete M Posted November 4, 2007 Share Posted November 4, 2007 To install a late model AX-15 into an ex-peugeot truck you would need a pilot bushing from a 70s era CJ. My guess (and this is only a guess) is that the nv3550 would need the same. It's a $2 part (which is important because there were a couple options and the other one was like $10). Link to comment Share on other sites More sharing options...
ejndssn Posted November 4, 2007 Share Posted November 4, 2007 I would agree with Pete as for replacing the pilot bushing. I did the swap from ba10/5 to ax-15 internal slave to ax-15 external slave cylinder and notice that there is a difference between pilot bushings I’ve got lucky between ba10/5 and the internal ax-15 after that there is a difference in pilot bushings from external ax-15 and internal ax-15 slave cylinders. its a pain to get them out :brows: but its worth the assurance that you got the right stuff. I do believe that NAPA has the part and also believe that it would be the same PB as the one for the ax-15 94+ but its always good to double check Link to comment Share on other sites More sharing options...
bpm4x4 Posted November 4, 2007 Share Posted November 4, 2007 The part number is pb-77 hd (Bower) for the ax-15 swap, the Dorman line has that bushing under a different part number, and that is the $2 one. I would get one and see if it will fit on your NV shaft, I did some checking on NAPA's web site and it may not work, or something custom may need to be done. I know others have done this swap, and may be able to confirm that this bushing will work. Link to comment Share on other sites More sharing options...
