4 minutes ago, Jesse J said:
they look good! where did the crossmembers go?
I did alot of research online about keeping vs eliminating, and found they weren’t really needed. The driver side was completely gone, and the passenger side was too far pitted to salvage. I just cut where the studs were and welded those sections back in.
ok cool they look really good. was that rattle can bedliner?
The base was por 15, then a floor pan primer, and two coats of a spray on bedliner. for the underside by the exhaust I used a ceramic high temp coating. And thanks
18 hours ago, ghetdjc320 said:
Your floor mats will fit better without the braces lol
Your right, haha. I think I’ll leave them bare, though. I put rubber drain plugs on each side I’ve been using alot, and until i find this leak, ill leave em out
