Antman Posted December 23, 2020 Posted December 23, 2020 its black exterior maroon interior bench seat cloth sliding back glass. Has molding and also has what seems factory added stickers "the shadow" on fenders and pinstripe that match. ... also possible i am the second owner Engine / Trans / Transfercase / Front axle / Rear axle / Wheelbase 4.0 fuel injected automatic coloumn shift 2WD unsire of rear diff. Manual windows and locks . It came with a few odd dealer installed parts like running boards,bed cover, stickers in the door jam coincide Build date: (its on the driverside door sticker, in the form of month and year) sticker is there but all identifying markings have rubbed off Current Location: Region will do, state, and area of state. Truck came from FLA there is a. Factory sticker in the door jam but is currently in TN Status: Is it still on the road, is it in the junkyard? Project awaiting work? Its my project but it is road worthy and i do drive it. Ive only had it about a week and am worming on it a little everyday so i will be posting more
jdog Posted December 23, 2020 Posted December 23, 2020 welcome, This truck has a oxygen sensor recall build:6/24/87 Body:tl61 *A6 Vinyl Trimmed Bucket Seats -H9 APA Monotone Paint CBA Straight Back Bench Seat CGX RR Head Restraints Outboard Seating CKA Carpets - Floor and Cargo Area DGS 4-Speed Automatic AW4 Transmission ERB 4.0 I6 MPI Engine GAC Tinted Glass Windows HCC Do Not Use - See HCA JJA Cigar Lighter LMA Halogen Headlamps MD8 Delete Front License Plate Bracket NAA Federal Emissions NHB Auxiliary Transmission Oil Cooler NMB Standard Duty Engine Cooling PX6 Paint QX6 Paint SBA Power Steering TBG Compact Spare Tire TBL Inside Mounted Spare Tire WJD 15X7.0 Styled Steel Wheels 3LR DESCRIPTION NOT AVAILABLE
Antman Posted December 23, 2020 Author Posted December 23, 2020 What doea tgis recal consist of ...o know that it needs on as its broke off lol
jdog Posted December 23, 2020 Posted December 23, 2020 RECALL 561 - 4.0L ENG. FED. VEHICLES - OXYGEN SENSOR 1988 Jeep Cherokee EMISSION RECALL BULLETIN EMISSIONS RECALL #561 - OXYGEN SENSOR Model(s): 1987-90 (XJ) Jeep Cherokee, Wagoneer 1987-90 (MJ) Jeep Comanche Bulletin No.: 561 Date: October, 1993 NOTE: This is an Emission Recall bulletin. VEHICLES AFFECTED 1987-90 Jeep Cherokee and Wagoneer (XJ); and Comanche (MJ) vehicles equipped with a 4.0L engine and located outside of California. SERVICE INFORMATION Failure of the oxygen sensor on the listed models, may cause a vehicle to be in violation of Federal Emissions Standards. To correct the condition, the oxygen sensor must be replaced with an improved design sensor. Details of this service action are explained in the following sections. SERVICE PROCEDURE VIDEOTAPE No videotape of the service procedure for this recall will be provided. DEALER NOTIFICATION & VEHICLE LIST INVOLVED DEALERS Each dealer to whom involved vehicles were invoiced (or the current dealer at the same street address) will receive a copy of this dealer recall notification letter and a list of the involved vehicles by first class mail. The Vehicle List is arranged in Vehicle Identification Number (VIN) sequence. Owners known to Chrysler are also listed. The lists are for dealer reference in arranging for service of involved vehicles. ALL DEALERS Each Jeep & Eagle dealer will receive a copy of this dealer recall notification letter by first class mail. DIAL SYSTEM FUNCTION 70 All involved vehicles will be entered to DIAL System Function 70 at the time of recall implementation for dealer inquiry by VIN as needed. PARTS INFORMATION IMPORTANT: A quantity of parts will be distributed initially and billed to all involved dealers. This quantity will cover a portion of the total vehicles involved. Additional parts will ba supplied as indicated in the Special Parts Supply Message with this notification letter. Each involved dealer, to whom vehicles in the recall were invoiced (or the current dealer at the same street address), will receive enough Oxygen Sensor Packages, Recall P/N C3905610, to service 25% of those vehicles (minimum of 5 and maximum of 20 packages). Each uninvolved dealer will receive 5 parts packages to service vehicles upon request. Each parts package contains the following components: PARTS INFORMATION PARTS INFORMATION TABLE Description Qty. Oxygen Sensor 1 Instruction Sheet 1 OWNER NOTIFICATION & SERVICE SCHEDULING All involved vehicle owners known to Chrysler are being notified of the service requirement by first class mail. They are requested to schedule appointments for the service with their dealers at the earliest possible date. A copy of the CUSTOMER NOTIFICATION LETTER is in this bulletin. Enclosed with each owner notification is an Owner Notification Form. The involved vehicle and recall are identified on the form for owner or dealer reference as needed. SERVICE PROCEDURE A. OXYGEN SENSOR INSPECTION 1. Raise Vehicle on a hoist and locate oxygen sensor in exhaust manifold as shown in Fig. 1. a. If the oxygen sensor has a metal stone shield around the sensor body continue with Step B. b. If the sensor does not have a stone shield, a new sensor has already been installed and no further service is required. WARNING: Exhaust manifold becomes very hot during engine operation. Allow engine to cool before removing oxygen sensor. Disconnect the oxygen sensor electrical connector. Remove oxygen sensor using a crowfoot socket. Clean exhaust manifold threads. 4. Install provided oxygen sensor (P/N C3905610). Tighten to 30 N.m (22 ft-lb). Connect oxygen sensor connector. Lower vehicle. http://jeep-manual.ru/images/letter2/recall_561_40l_eng_fed_vehicles_oxygen_sensor_html_me3a24ba.jpg 97B53315 Fig. 1: Wire Connector & Oxygen Sensor - Location CUSTOMER NOTIFICATION LETTER EMISSIONS RECALL - OXYGEN SENSOR REPLACEMENT Dear Chrysler Vehicle Owner: Chrysler Corporation and the Environmental Protection Agency has determined that the oxygen sensor on certain Cherokee, Wagoneer and Comanche models may be susceptible to failure. Failure of the oxygen sensor may cause your vehicle to be in violation of Federal Emissions Standards. For this reason, we are asking you to return your vehicle, identified by the Vehicle Identification Number on the enclosed form, to your dealer for a special service repair. This service will be provided free of charge. The needed instructions have been sent to all involved dealers. The service will not hurt your engine performance or fuel economy. To obtain this service: Contact your Jeep/Eagle dealer as soon as possible to make an appointment for the free service. Take the enclosed Owner Notification Form with you at the time of your appointment and give it to your dealer. The form identifies the vehicle and recall for which service is required. The dealer will inspect and replace the oxygen sensor if necessary. The service will take about one-half hour, but additional time may be required depending on how service appointments are scheduled and processed. In order to ensure your full protection under the emission warranty made applicable to your vehicle under Federal law, and your right to participate in future recalls, it is recommended that you have your vehicle serviced as soon as possible. Failure to do so could legally be determined to be a lack of proper maintenance of your vehicle. Further, without this repair your vehicle may fail a state or local emission inspection test. If you have any problem obtaining the service, please contact the Chrysler Zone Service Office in your area. (It is listed under "Service Assistance" in your Owner’s Manual.} A Zone representative will arrange for prompt servicing of your vehicle. If you are still unable to obtain the repair as described in this letter within a reasonable time, you may also contact the Manufacturers Operations Division of the Environmental Protection Agency (6405d), 401 M Street S. W., Washington, D. С 20460. We regret any inconvenience this action may cause, but trust you understand our interest in clean air and in your continuing satisfaction with our product. Thank you for your prompt attention to this important matter. Customer Services Field Operations Chrysler Corporation http://jeep-manual.ru/images/letter2/recall_561_40l_eng_fed_vehicles_oxygen_sensor_html_690ca6a7.gifCOMPLETION REPORTING & REIMBURSEMENT Claims for vehicles which have been serviced must be submitted on the DIAL System. Claims submitted will be used by Chrysler to record recall service completions and provide dealer payments. Use ONE of the following labor operation numbers and time allowances: Labor Operation No.: 25561181 - Inspect Oxygen Sensor Time Allowance: 0.2 hr. Labor Operation No.: 25561182 - Replace Oxygen Sensor Time Allowance: 0.3 hr. Add the cost of the recall parts package plus applicable dealer allowance to your claim. Parts Return Initially, a small number of oxygen sensors are required to be returned to the Warranty Material Return Center. When an adequate number of returned parts have been accumulated, Parts Return Documents will no longer be generated and parts are to be discarded. NOTE: See Warranty Policy and Procedure Manual, Chapter 6, Subsection H for complete recall claim processing and material return instructions. Vehicle Not Available If a vehicle is not available for service for a known reason, let us know by filling out the pre-addressed Vehicle Disposition Form portion of the Owner Notification Form or describe the reason on a postcard and mail to: Chrysler Corporation 429-10-04 P.O. Box 1919 Detroit, Michigan 48231-1919 Following the above procedures will expedite the processing of your claim. If you have any questions or need assistance in completing this action, please contact your Zone Service Office.
Pete M Posted December 23, 2020 Posted December 23, 2020 your full build sheet is much longer than what we can dig up front chrysler. a lot of info was unfortunately lost at AMC before chrysler got it into their computers. if you look at a 90-92 MJ in the registry you'll see what I mean. but you could still have the original sheet of paper in your truck! possible locations are under a bench seat, behind a door card, behind the rear wall panel, or wadded up under the dash on the pass side.
Pete M Posted December 23, 2020 Posted December 23, 2020 the mounting holes are mirrored top to bottom so it's easy to flip it.
Antman Posted December 24, 2020 Author Posted December 24, 2020 Thanks again I'm gonna start pulling interior this weekend if the rain lets up for cleaning hopefully i will find the original build sheet
jdog Posted January 31, 2021 Posted January 31, 2021 Selling Dealer: EARTH JEEP-EAGLE INC Kissimmee, FL
