I know that the Peugeot and the AX-15 have different numbers of splines on the output shaft where it goes into the transfer case. When did the AW4 switch to the same number of splines as the AX-15? I am trying to figure out if I should save the 96 231 that came behind my AW4 for my 97 AX-15. Thanks
