Speedometer cable
Grey cable is the OEM that I replaced, but now its back in and bouncing after white lithium grease.
Replaced ( black cable ) was very very long, and hit the exhaust and melted. I zip tied the slack up to the arm but it melted from the engine bay area.
Thank you guys.
10 hours ago, Minuit said:
There should be a P-clip on the driver side upper control arm bolt that keeps the cable away from the exhaust. But saying that, my original cable doesn't look like it has as much slack as yours.
This is a replacement Pioneer one from.......autozone :doh:
6 hours ago, 87MJTIM said:
Looks like you have cable for a 4wd MJ.
NAPA has the longer and shorter cables available.
I just ordered a new one from rockauto that seems better designed even though its also a Pioneer cable - CA-3068
