Cernics74 Posted October 27, 2020 Share Posted October 27, 2020 I’m about a year into this thing. I have changed careers so I now have time to put some time in and get it going. It started life as a 1990 2.5L pioneer that was lifted and 4.0 swapped. Now it’s under the knife again for a list of upgrades. Follow along and check it out. I do apologize for starting the thread a bit late. 👌🏻 So far I have stripped the Jeep, sandblasted inside and out, repaired a few places in the floor I didn’t like, and I epoxy sealed the body and raptor lined the rear “frame” and under body. Link to comment Share on other sites More sharing options...
Cernics74 Posted October 27, 2020 Author Share Posted October 27, 2020 Before I stripped all the paint I began metal work on the firewall and and other tabs and mounts to accept the 97+ dash conversion. I used a few parts from a donor xj. Link to comment Share on other sites More sharing options...
Cernics74 Posted October 27, 2020 Author Share Posted October 27, 2020 Started fitting and burning in the trussScooped up a couple 09 superduty axles from my local pull a part. Link to comment Share on other sites More sharing options...
Cernics74 Posted October 27, 2020 Author Share Posted October 27, 2020 xd232 beadlocks and 40’s Link to comment Share on other sites More sharing options...
Cernics74 Posted October 27, 2020 Author Share Posted October 27, 2020 Shaved the battery tray and air box locations to open the wheel wells a bit. Link to comment Share on other sites More sharing options...
Pete M Posted October 27, 2020 Share Posted October 27, 2020 this is going to be good Link to comment Share on other sites More sharing options...
Cernics74 Posted October 27, 2020 Author Share Posted October 27, 2020 Burned in some frame horn brackets to help with rigidity. Link to comment Share on other sites More sharing options...
Cernics74 Posted October 27, 2020 Author Share Posted October 27, 2020 Rear axle is stripped and under the frame. Mocked up some Rear 4 link brackets. Link to comment Share on other sites More sharing options...
Cernics74 Posted October 28, 2020 Author Share Posted October 28, 2020 Got the rear axle truss partially burned in so I can start measuring for control arms. Link to comment Share on other sites More sharing options...
Cernics74 Posted October 28, 2020 Author Share Posted October 28, 2020 Started fitting the engine and realized I should trim the firewall a bit to accommodate the bell housing. Link to comment Share on other sites More sharing options...
CPH-0628 Posted October 29, 2020 Share Posted October 29, 2020 I like the way this one is starting out. Looking like a cool build. Sent from my SM-G950U using Tapatalk Link to comment Share on other sites More sharing options...
buxmj Posted November 21, 2020 Share Posted November 21, 2020 Great build already, thanks for sharing and looking forward to some updates! Buck. Link to comment Share on other sites More sharing options...
Cernics74 Posted December 31, 2020 Author Share Posted December 31, 2020 Got the firewall/tunnel shaped and burned in. Man does the metal suck on these trucks. Also starting to bend and fit 3/16 plate for inner frame stiffeners. Link to comment Share on other sites More sharing options...
