My comanche has an issue with overheating while I am off roading. Now, I've heard talk about people putting secondary cooling fans in their cherokees, and that it would work with my comanche, but where do I get that fan and how do I install it?
The easiest is to grab an aux fan from an XJ/MJ (make sure the mounting tabs are in good shape) and install it in your truck. Then wire it up (through a relay) to a switch in the cab. How hot is your truck getting?
what about the radiator is this a stock or a aftermarket replacement i have had great success with a three core unit and it is barely over the 220 range in the mid of summer and the engine has been stroked too. :brows: maybe its time for a replacement :dunno:
