sinnaevd Posted October 26, 2007 Share Posted October 26, 2007 soooo here goes. I have learned quite a bit about trying to swap pieces of axles instead of whole assemblies this week. What a PITA. what i have is a 2wd 86 manche 4 cyl. Had a blown engine and needed a front bearing. Got the bearing prices, they want 300 bucks because it is a whole assembly not just pack of bearings due to the unusual design of hub part of the axle. I said no thanks as I can get a whole axle for under 50 and just toss it in, since this truck is 2wd it would be non functional anyway. So i manage to be given an 89 D30 for the price of on the house that I was going to swap in instead of the 2wd axle. My buddy was going to give me a hand (or vise versa) but he was in exams and I need to get the truck out of the garage withing the next two weeks. So we thought hmmm...maybe we can take off the inner axle shafts and just use the spindle part? Well after pulling everythign apart and hammering out the u joints turns out the 4wd hun and spindle is different, but I am get to find out why from quick inspection. So I said okay, no problem. I can swap over most brake components an it will be problem free right? well I took some measurements of the parts that the brake pads sit on. Under first measurements I find out that it should work. So i pull everything apart, get it swapped over to the dummy D30 and find out again the brakes won't work, but they just barely don't fit. SO in the end I have learned not to try and swip swap parts between axles. It is a big waste of time (about 5 hours so far). In the end, the original solution will be the correct one. and I now have to replace some u joints :cry: Link to comment Share on other sites More sharing options...
sinnaevd Posted October 26, 2007 Author Share Posted October 26, 2007 but i did manage to make some delicious peanut butter cups. Link to comment Share on other sites More sharing options...
Pete M Posted October 26, 2007 Share Posted October 26, 2007 You wouldn't be the first to learn the hard way that 2wd front axle parts are different than 4wd front axle parts. :( Link to comment Share on other sites More sharing options...
Oizarod115 Posted October 26, 2007 Share Posted October 26, 2007 :oops: coulda tolja that one mate... the P/Ns are different ;) Link to comment Share on other sites More sharing options...
sinnaevd Posted October 26, 2007 Author Share Posted October 26, 2007 albeit the PN's are different i still figured they may work. oh well, it was intersting. It's better then learning about the venturi effect in school Link to comment Share on other sites More sharing options...
pingpong Posted October 26, 2007 Share Posted October 26, 2007 Just think.. you could have swapped the whole axle under it.. and been that much closer to being a 4wd Jeep :dunno: Most Napa's have parts diagrams... and often it is easier to look at the parts.. and tell they won't work instead of trying it :brows: Link to comment Share on other sites More sharing options...
sinnaevd Posted October 26, 2007 Author Share Posted October 26, 2007 That was my biggest problem, with my current health issues swapping over parts was my only option to getting it back on all 4's if I was healthier and able to move the heavy axle I would have not even bothered messing with it lol If my buddy wasn't in exams he would have one it for me, but I didn't want to burden him with that while he is studying (even though it is technically his comanche as he paid for it) oh well. I learned some interesting things about how stupid the 2wd front axle is anyway lol Link to comment Share on other sites More sharing options...
