Can someone post pictures and hose, cables and gas line routing to the weber carb? Will installing the weber make the MJ fail smog test in California? It's for a 2.8l GM V6. Thanks.
1986 Jeep Comanche X
4WD GM 2.8L V6
Front: Stock Dana 30
Rear: Stock AMC 20
Los Angeles CA
Sent from my SM-G955U using Tapatalk
I ran 3 Webers in the past. Does yours have an electric choke? There are a few variations of the Weber 38. All are fairly self explanatory. Vacuum to distributor, fuel in (regulated to 3.5psi), electric choke line and throttle cable/kickdown if applicable. Can probably dig up a diagram if you have the exact model handy
I have the Weber 38 DGES with electronic choke.
4WD GM 2.8L V6
Rear: Stock AMC 20
Los Angeles CA
