skimore11 Posted October 23, 2007 Share Posted October 23, 2007 I am working on replacing my clutch and while I had the BA10 out. I decided the rubber isolator portion of the transmission mount is shot. I can not find any place that has it locally or online. Every one has the 2625 which must be for the AW4. So what is the part number I need or do I need to buy the whole assembly for $100+ ??? You can see the rubber isolator sticking out the side of this one. http://www.shop.com/JEEP_CHEROKEE_Trans ... urceid=255 Thanks Link to comment Share on other sites More sharing options...
Carl'sMJ Posted October 23, 2007 Share Posted October 23, 2007 I just replaced the transmission mount on mine with one I bought from Quadratec. It was a Daystar polyurethane replacement and cost $50. I have an AX15 and needed the 3" style. They also sell a 1-1/2". Link to comment Share on other sites More sharing options...
carnuck Posted October 24, 2007 Share Posted October 24, 2007 AX-15 one is different Link to comment Share on other sites More sharing options...
dakal Posted October 24, 2007 Share Posted October 24, 2007 yes it is. Link to comment Share on other sites More sharing options...
skimore11 Posted October 24, 2007 Author Share Posted October 24, 2007 Well the first step tonight is to attach the trans mount. It looks like I will be putting the old one back on for now. Any creative ideas on adapting a mount from the AX or anything else would be appreciated. Or does anyone have a mount that is no longer in use? There has to be one some where. Every article I found was about replacing the BA10. Link to comment Share on other sites More sharing options...
over2land Posted October 24, 2007 Share Posted October 24, 2007 On the 2wd, it looks like there is no way to get the rubber replaced on that mount. I looked at swapping the AX15 mount in, and while it would generally have been in the wrong place, the 4 bolts that hold it to the trans were of the wrong pattern, and the actual plate that bolts to the trans interfered with the transmission itself and would have required a ton of grinding to clear. I'm not sure if the 4WD and 2WD mounts are the same. Link to comment Share on other sites More sharing options...
HOrnbrod Posted October 24, 2007 Share Posted October 24, 2007 From the parts manual: P/N 52001313, Cushion, Rear Transmission Mount, 2WD, $6.88 P/N 52001180, Cushion, Rear Transmission Mount, 4WD, $42.52 Link to comment Share on other sites More sharing options...
skimore11 Posted October 25, 2007 Author Share Posted October 25, 2007 Thanks for looking. But those look like the same as the ones I have gotten that don't fit. Search shows they are for the 2.5L I have put my old one back in. It isn't completely shot, so we will see. Would have been nice to replace it while it was out. Now I am thinking I should keep looking though, so if it does give out I have one ready. Link to comment Share on other sites More sharing options...
HOrnbrod Posted October 25, 2007 Share Posted October 25, 2007 Thanks for looking. But those look like the same as the ones I have gotten that don't fit. Search shows they are for the 2.5L I have put my old one back in. It isn't completely shot, so we will see. Would have been nice to replace it while it was out. Now I am thinking I should keep looking though, so if it does give out I have one ready. Sorry, didn't know you had the 4.0L. You need p/n 52002334. According to the parts manual, the AW4 and the BA10 use the same cushion, but the brackets are different. Link to comment Share on other sites More sharing options...
