Is it possible to put a 96 gauge cluster into my 89 (my 89 will be getting a 96 engine, but not the full HO swap). I know cruiser's website says that some sensors need to be changed to have the HO engine work in a Renix, but I am not sure if I keep some HO sensors if they will work with the full cluster. I will be swapping 4.0 for 4.0. I will also be swapping to a 97 AX-15.
Someone will correct me if I'm wrong, but, the pin out won't be the same. So, no, that cluster won't work with your renix era dash wiring
Sent from my Pixel 2 XL using Tapatalk
Gotcha, thanks!
It works, I've put a '96 full cluster in my '88 Renix 2.5. I got the connector with it when I snatched it at the JY. Almost all the wires are there, just different colors. I  used diagrams and pinouts for 1988 and 1996 and cross-referenced them to figure out the connector swap. I had a poverty-spec cluster stock with dummy lights so I had to get different oil pressure and coolant temps sensors. I also had to go from cable to electronic speedo. Got the electric speedo sensor and made my own 3-wire harness. Pretty sure the new cluster came from a 4.0, and my truck is a 4-banger, and everybody said that the tach wouldn't read right, and those year clusters don't have an adjustment for it, but mine strangely reads bang-on, so big mistery there. Also note that your gas gauge will read backwards, unless you get a 1991 sending unit I think? Can someone confirm this?
Thanks!
I should have been more specific. When I said the pin out is different, I mean it's not plug and play. I assume most anything can work with enough splicing and doodiddling.
Thank you!
