1J7FT26L7LL143638
Psveritas
Hello all, figured it's time I make formal registry / hello post.
1990 Comanche Sportruck
4.0 / 4 speed auto / 2WD / SWB
No idea on build date, that sticker is far gone.
PIcked it up from Ohio, almost West Virginia area, and hauled it up to Michigan, in the Saginaw Bay area where it now resides.
It does run, although it does need some work done to run properly. Water pump, vacuum, fuel pump, etc. all need to be replaced. Probably a hose refresher. Goal is to restore as close to a stock look as possible, but I don't mind mechanical upgrades. Just no lift or 35's in it's future. Some body work needed on passenger side where she's rusted, as well as floor boards.
Pretty basic Comanche (sportruck after all) that is a 2wd. May do a 4wd in the future... Column shift auto, manual doors, White exterior with the burgundy interior, bench seat that's original and in immaculate condition. Dash, etc, all in amazing condition. Do need to fix driver side window (stuck down, or missing) and get some audio working (will upgrade that system). Beautiful truck with minor rust spots other than a rusted through passenger rocker as mentioned.
I'm now the owner, and it's sitting at my private residence where she's going to go through a lot of TLC love and care.
Bought it on my father's (now deceased) birthday. He used to own a VERY similar setup (his was 4wd) and was a mechanic / shop owner for years until he was forced to stop due to health. I was his caregiver for years. So this is going to be the best project I've done to date.
*E1 Cloth Bench Seat
-H9
142 Zone 42-Detroit
1AA U.S. Dealer Retail
5KK First American Title Insurance CO.
ALA
ALK
APA Monotone Paint
BAY 105 Amp Alternator
BCY 475 AMP BATTERY
BGA Power Front Disc/Rear Drum Brakes
CBA Straight Back Bench Seat
CKJ Black Vinyl Floor Covering
CSR Passenger Assist Handles
DGB All 4-Speed Automatic Transmissions
DGS 4-Speed Automatic AW4 Transmission
DHT Shift-on-the-Fly,P/Time T/Case
DMD 3.55 Rear Axle Ratio
DRJ 175MM Rear Axle
EAA All Engines
EAF ALL FUEL INJECTED ENGINES-GAS
ERB ENGINE - 4.0L I6 MPI GAS
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEH Fixed Door Vent Glass
GNA Rear View Day/Night Mirror
GRV Left Manual Mirror
GUA Open
HAA Air Conditioning
JAZ DO NOT USE - See JP, KA classes
JCA 85 MPH Primary Speedometer
JJA Cigar Lighter
K3Z STRIPE/BADGE/MOLDING/COLOR
KDD
LBC Glove Box Lamp
LCJ DOME/READING LAMP B-PILLAR
LMA Halogen Headlamps
MB1 Black Front Bumper
MBJ Black Front Bumper
MDA Front License Plate Bracket
MFF Black Grille
MHB Bright Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMJ DRIP TROUGH MOLDINGS - TYPE I
NAA Federal Emissions
NBK EVAP Control System
NF2 18.5 Gallon Fuel Tank
PW7 Bright White Clear Coat
QW7 Bright White Clear Coat
RA8 Delete Radio
SBA Power Steering
SCB  Steering Whl
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
TAA All Tires
TBC Compact Spare Tire
TBM Tire Carrier Winch
TNC P195/65R15 BSW AS Touring Tires
WJK 15X6.0 Styled Steel Wheels
WLY All Steel Wheels
WMC Bright Wheel Trim Rings
XBS Pickup Box
YAA Build To U.S. Mkt. Specifications
YEP Manuf Statement of Origin
YGE 5 Additional Gallons of Gas
Z01 Rear Spring Group I
Z1A GVW/Payload Rating
Z58 Left Front Spring Group Viii
Z78 Right Front Spring Group VIII
Build date 9/20/89
Body code TL61
  • 5 months later...
  • 2 months later...
