cozee Posted October 19, 2007 Share Posted October 19, 2007 Lost my tail lights on my '88. Fuse is good (Also try them with a new one), switch works (tried a new one here also), but no tail or dash lights. If I power them through the trailer plug all is well. Any ideas before I start looking later this week end? Link to comment Share on other sites More sharing options...
Pete M Posted October 20, 2007 Share Posted October 20, 2007 When I lost brake lights in my 88 it was due to corrosion in the wire harness connector located behind the drivers side rear tire. Link to comment Share on other sites More sharing options...
cozee Posted October 20, 2007 Author Share Posted October 20, 2007 But I am getting power back up to the switch because I get dash lights also when I power the circuit through the trailer plug. I don't have a schematic but am guessing maybe a wire problem coming out of the fuse block. Link to comment Share on other sites More sharing options...
carnuck Posted October 21, 2007 Share Posted October 21, 2007 It could be corroded at the fuse, and cutting power when the lights draw. Kind of like a loose battery terminal works till you hit the start switch, then it cuts off till you let go of the key. Link to comment Share on other sites More sharing options...
