Swampy Posted August 10, 2020 Posted August 10, 2020 Anyone ever use something like this for a 1996 xj clutch master and an external slave on an AX15?? The fittings look the same and the stock line is 42" I believe.
ghetdjc320 Posted August 10, 2020 Posted August 10, 2020 I’ve seen them used before and it should work great.
Swampy Posted August 11, 2020 Author Posted August 11, 2020 2 hours ago, ghetdjc320 said: I’ve seen them used before and it should work great. Awesome Thank you
mjeff87 Posted August 11, 2020 Posted August 11, 2020 I can't see your pic, but I used one on mine. Got it from Advance Adapters. The fittings in the back of the master cylinder and slave are held in with a tiny roll pin...just use a small punch (or a finishing nail) and pop them out.
