ghetdjc320 Posted July 29, 2020 Posted July 29, 2020 Have an odd little vacuum sound. I run a dual diaphragm 8” booster and an electric vacuum pump that runs fairly high vacuum (24in). Recently, when I let off the brake pedal their is a vacuum suction sound that lasts for just a second then sounds like a valve closes shut. Almost sounds like something is a bit sticky in the booster and needs some oil. The booster isn’t leaking at all while breaking and works fine otherwise. Any ideas what it could be?
Pete M Posted July 30, 2020 Posted July 30, 2020 vacuum escaping past a seal? I've never dealt with a system that runs that high.
