trying to find a fuel line
Does anyone know where to get the fuel line that goes to the fuel pressure regulator? The plastic clip on mine broke when I replaced the fuel pressure regulator, and I can't seem to find the lines through any online retailers, and my local auto parts store says that they don't carry them and can't even order them. if someone knows where to find one and could get me a link I would greatly appreciate it. also if this post needs to be moved that's fine.
6 minutes ago, FrankTheDog said:
There should be a white plastic insert that goes in there that you can get unless you broke the black part too.
The parts store genius told me that the white plastic insert doesn't come separate from the fuel line. that insert is what broke.
IMG_0326.HEIC
1 minute ago, FrankTheDog said:
They do, somewhere, look on the help rotisserie. There should be a package of them there. I can’t remember where I got mine but I did get a package of them separately.
Ill have to look tomorrow. they are closing soon, and that extremely helpful excuse of a parts store clerk won't be there.
It’s in the help! Product aisle. It’s a standard Chrysler fuel injection quick connect. It will have a barb for a 5/16 or 3/8 hose so you’ll have to grab some fuel injection rates hose from the store also. There are also adapters for the quick connect to an fittings if you’d like to go that route but those are pricey.
Dorman 800-120 and 800-121 are the two part numbers for the supply and return line fittings for the fuel rail. And both have hose barbs
