Jrwhite3230 Posted July 8, 2020 Posted July 8, 2020 I'm needing help on my 2wdrive swap to 4wdrive I'll add photos of the transmition I purchased from another jeep I'm bv trying to identify it because th e identifiable tags are missing and I believe the front and rear axles are from the same jeep cherokee the transmition is from but I'll post photos to see if any of you guys can identify it !?
Pete M Posted July 8, 2020 Posted July 8, 2020 32 minutes ago, jrwhite3230 said: I'm needing help on my 2wdrive swap to 4wdrive I'll add photos of the transmission I purchased from another jeep. I'm trying to identify it because the identifiable tags are missing and I believe the front and rear axles are from the same jeep cherokee the transmission is from, but I'll post photos to see if any of you guys can identify it !? looks to be an AW4 transmission you've got there.
Jrwhite3230 Posted July 14, 2020 Author Posted July 14, 2020 Thanks for that info I’ll try and confirm that further so I can get the correct linkages and stock parts that came with this transmition like shifter ect ...
