Went to pump gas on my lunch came back out to the truck and it had fluid on the floor took some pics and video, anyone had this issue before? I'm stuck but O’Reillys is 2 mins away
It looks to be the line leaking
1989 4.0
Renix
Scratchy Ba/10
2wd
Stock
Short bed base
yup.  :L:  looks like a new clutch line is in your future.
as it turns out you don't actually need the clutch pedal to drive.  turn off truck, put it in first, crank the engine and the starter will pull the truck forward and it'll fire up and go.  be prepared for it to fire and go.  then you just need to match rpms to shift. :comanche:  the biggest hassle is having to turn the truck back off at a stop light to repeat the procedure when the green flashes.  drove my '90 home from Ohio this way.  the guy I just bought it from said it had a leak but would go all week before needing to top off.  it of course lasted about 10 miles. :(
yup.  thumbs.gif  looks like a new clutch line is in your future.
as it turns out you don't actually need the clutch pedal to drive.  turn off truck, put it in first, crank the engine and the starter will pull the truck forward and it'll fire up and go.  be prepared for it to fire and go.  then you just need to match rpms to shift. comanche.gif  the biggest hassle is having to turn the truck back off at a stop light to repeat the procedure when the green flashes.  drove my '90 home from Ohio this way.  the guy I just bought it from said it had a leak but would go all week before needing to top off.  it of course lasted about 10 miles.
Thanks a million this will help me get it home and order the line
1989 4.0
Renix
Scratchy Ba/10
2wd
Stock
Short bed base
