Patrick_Rash Posted July 4, 2020 Posted July 4, 2020 Planning on doing a full restoration with either a I6 or a LS1 swap. I also plan on doing an axle swap and throwing some 35's on it. 1886 COMANCHE, XLS V6 2.8L/COMMAND TRAC/POSSIBLE AMC 20 Build date: Not able to read Current Location: Aurora, Colorado Status: Project awaiting work
eaglescout526 Posted July 4, 2020 Posted July 4, 2020 *ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT -ZZ ADA LIGHT PACKAGE ADL SKID PLATE GROUP AJT RADIO PREP GROUP AJZ BAC 75 AMP ALTERNATOR BCQ Battery - 750 Amp Maintenance Free CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ DDQ Transmission - 5-Speed Manual EFB ENGINE - 2.8L GM 6CYL GAC ALL WINDOWS - TINTED GLASS GFD SLIDING RR WINDOW GPB DUAL - O/S MIRR PKG - LOW MOUNT - CHROME HC0 All Vehicles W/O Air Cond HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JFH TACHOMETER - MECH JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MLDGS - VINYL LBB COURTESY LAMPS (BELOW PANEL) LMA HALOGEN HEADLAMPS LPE EXTERIOR CARGO LIGHT MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED MFD BRIGHT GRILLE - TYPE I NAF HIGH ALTITUDE EMISS CONTROL PKG NFA TANK - 20 GAL FUEL NMB ENGINE COOLING - STANDARD DUTY SBA POWER STEERING SUA TILT STEERING COLUMN Build date 8/1/85 Body code JP62
Patrick_Rash Posted July 4, 2020 Author Posted July 4, 2020 With a build date of 8/1/85, is the firewall far back enough to do a I6 conversion pretty easily?
eaglescout526 Posted July 4, 2020 Posted July 4, 2020 being an 85 it probably may be too early to have it fit without modification.
jdog Posted July 4, 2020 Posted July 4, 2020 8 minutes ago, Patrick_Rash said: With a build date of 8/1/85, is the firewall far back enough to do a I6 conversion pretty easily? this would be better asked in the pub you will get more eyes and probably an answer That is a nice looking longbed
