Chad R Posted June 12, 2020 Share Posted June 12, 2020 Just got the floors all done and planned on getting my 86 mj back on the road when a nice white cloud came out the tail pipe. Oil looks nice and milky now, oh joy! My Comanche is a 1986 2.5 automatic fuel injection with 197k. my question is why I have the head off I plan on doing a valve job, valve seals is there anything else I should do why I have the head off or should check. Link to comment Share on other sites More sharing options...
eaglescout526 Posted June 12, 2020 Share Posted June 12, 2020 You can take out your tappets and see how clean they are while you have the head off. Otherwise you have all the main bases covered for the job. Link to comment Share on other sites More sharing options...
MontanaManche Posted June 13, 2020 Share Posted June 13, 2020 i just did the same on my 2.5, one thing i would do is make studs to align the head onto the block. if your using new bolts just cut the heads off the old ones or what i did is bought some bolts from ace that had the same threads and cut the heads off, otherwise its a huge pain to get the head aligned without messing up the gasket. also having a friend to help put the head back on is a huge help, its heavy even for a 4 cylinder Link to comment Share on other sites More sharing options...
Chad R Posted June 13, 2020 Author Share Posted June 13, 2020 19 minutes ago, MontanaManche said: i just did the same on my 2.5, one thing i would do is make studs to align the head onto the block. if your using new bolts just cut the heads off the old ones or what i did is bought some bolts from ace that had the same threads and cut the heads off, otherwise its a huge pain to get the head aligned without messing up the gasket. also having a friend to help put the head back on is a huge help, its heavy even for a 4 cylinder I saw that on YouTube I did not realize the 2.5 did not have doll pins Link to comment Share on other sites More sharing options...
