AMC86Kid Posted June 10, 2020 Share Posted June 10, 2020 How do you remove the lower drive gear ? I need it to connect to the new speedo cable ? Link to comment Share on other sites More sharing options...
AMC86Kid Posted June 10, 2020 Author Share Posted June 10, 2020 Here’s what the new speedo cable look like Link to comment Share on other sites More sharing options...
JustEmptyEveryPocket Posted June 10, 2020 Share Posted June 10, 2020 That cable crosses to an 88 Comanche with 4.0L engine. Are you sure its correct for your year, engine, transmission (or transfer case)? Link to comment Share on other sites More sharing options...
JMO413 Posted June 11, 2020 Share Posted June 11, 2020 I believe you are holding part number 2 in your hand the cable should just unscrew. The OEM cable had the nice nut the aftermarket went cheap. Link to comment Share on other sites More sharing options...
JMO413 Posted June 11, 2020 Share Posted June 11, 2020 1 hour ago, AMC86Kid said: Here’s what the new speedo cable look like I have had 2 or 3 of these now. Let's just say exhaust is hot. All of them have not been smooth at the speedometer. I have found living the cable helps allot. I would do it when you install it. IMHO Link to comment Share on other sites More sharing options...
AMC86Kid Posted June 11, 2020 Author Share Posted June 11, 2020 I have got it apart now and it does work on the 86 but you just got to mod the back of the gauge to get the new cable to clip on, my old one appears to be the original one and the wire is all cracked up and peeling off Link to comment Share on other sites More sharing options...
Eagle Posted June 11, 2020 Share Posted June 11, 2020 3 hours ago, AMC86Kid said: Here’s what the new speedo cable look like That doesn't look like the right cable for an '86. You need the one that attaches to the speedo head with a metal clip and a screw. Link to comment Share on other sites More sharing options...
AMC86Kid Posted June 11, 2020 Author Share Posted June 11, 2020 Your right eagle it’s not all metal like the original one but I have no clue where to even buy an original one so I just got this one and it works just fine, plus it’s a little longer than the old one so you have more wire to work with behind the cluster Link to comment Share on other sites More sharing options...
