sinnaevd Posted October 14, 2007 Share Posted October 14, 2007 So turns out this 86 is a little odd when it came to the front dummy D30, and changing the bearings has to be done by a professional shop because its all goofy (or I could just use the bress but I imagin i would destroy the bearings the first time) So in goes a D30 that has been graciously donated by a buddy of mine, it has all new seals and bearings and steering stabilizer and brakes, which is nice because the 86 has brand new rotors pads and the calipers were in excellent shape. so now I have two extra sets of calipers and an extra set of rotors and pads for a rainy day. But since the 4wd front axle is going in, might as well make it functional right? otherwise its just silly in my opinion. The auto trans in this Manche now is kind of poop (the TF999 i think) the 3 spd auto is not highway friendly but serves the 4 banger well. I have an extra TF727 kicking around with tcase. I can flip the tcase but will the trans bolt onto a 4 banger? the 4 spd should be a bit more user friendly. it was off of a 360, so I thought the GM housing should be the same no? Link to comment Share on other sites More sharing options...
Tonkatruck Posted October 14, 2007 Share Posted October 14, 2007 http://comancheclub.com/forums/viewtopi ... highlight= I was asking a similar question, the consensus is that the bolt pattern will be different so you would require an adapter for the engine to tranny so its likely not worth the effort. Also, you shouldnt need to flip the tcase because Waggy's are typically DS drop. Link to comment Share on other sites More sharing options...
Eagle Posted October 14, 2007 Share Posted October 14, 2007 I have an extra TF727 kicking around with tcase. I can flip the tcase but will the trans bolt onto a 4 banger? the 4 spd should be a bit more user friendly. it was off of a 360, so I thought the GM housing should be the same no? Sorry, but no. The AMC V8s share the same bolt pattern as the 4.0L I6. The 2.5L I4 and the 2.8L V6 use a smaller, GM bellhousing pattern. They are not interchangeable. Link to comment Share on other sites More sharing options...
carnuck Posted October 17, 2007 Share Posted October 17, 2007 You can possibly use a 200R4 (if 2wd) or 700R4 from an S10 with 2.8V6 (don't know about the flexplate matchup tho) Link to comment Share on other sites More sharing options...
sinnaevd Posted October 17, 2007 Author Share Posted October 17, 2007 i think the consensus is that the TF999 is going to stay in until the deisel goes in. Once the deisel swap goes in, the NV4500 will be right behind it. but for now it makes sense just to keep the truck stock so it can be puton the road. Link to comment Share on other sites More sharing options...
carnuck Posted October 17, 2007 Share Posted October 17, 2007 At least you can slap a Jeep NP208J (or AM) onto it! Link to comment Share on other sites More sharing options...
