DravenBoris Posted May 29, 2020 Share Posted May 29, 2020 Alrighty this thread is going to be a complete breakdown of what parts from what year jeeps will complete this upgrade. Also what route is the best ad most efficent what route is the easiest what routes you can just make work Info to compile is which booster is easiest to use but benefits the truck the most, and if you’re in a pinch how to make the less common ones work which master is best to pull which don’t work at all which proportioning block is best with the caviot of future disc breaks. Ie, use cherokees or grands. ( this s assuming that you’re deleting weight valve) an help is appreciated once as much info is gathered as possible I’ll probably compile and do I straight forward breakdown of the info for future readers. And if this has bee done we’ll point me in the direction. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted May 29, 2020 Share Posted May 29, 2020 What year mj do you have? Link to comment Share on other sites More sharing options...
DravenBoris Posted May 29, 2020 Author Share Posted May 29, 2020 88 2wd. Idk how to d the signature Link to comment Share on other sites More sharing options...
WahooSteeler Posted May 30, 2020 Share Posted May 30, 2020 Go to top right corner beside your screen name, click on drop down arrow, go to account settings. Signature on menu on the left side of screen. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted May 30, 2020 Share Posted May 30, 2020 There are many different boosters that will work. 95 and later XJ with dual diaphragm boosters as well as WJ. None are a direct swap but if you own a grinder and drill you can make them work. A 95 xj booster is a perfect fit on the 91-92 mjs but requires modification for the brake light switch and pedal fitting for earlier mjs. Almost all boosters will require the same mods for the pre 91 mjs Link to comment Share on other sites More sharing options...
ghetdjc320 Posted May 30, 2020 Share Posted May 30, 2020 Dual diaphragm is great but check your engine vacuum at idle first. My engine has a custom cam that doesn’t produce much vacuum so I’m running a dual diaphragm pump with a leed electric booster Link to comment Share on other sites More sharing options...
DravenBoris Posted June 28, 2020 Author Share Posted June 28, 2020 Ended up using a 98 Cherokee booster master and will soon swap prop valve and elem wait sensor valve. I cut out maybe a 1/4- 1/2 section but I do believe I could have spaced it out with out cut and weld. will for sure need to get a different washer fluid bottle Link to comment Share on other sites More sharing options...
