Alfadad Posted May 23, 2020 Share Posted May 23, 2020 91 Comanche 6 cyl/ 5 spd/long bed 4x4. Having issues w tail lights. As you know, from top to bottom, 3 segments. On both sides: Top : brake light and turn signal. Middle: also brake light and turn signal, Bottom: back up light. All are working,but w headlights on, I have no constant tail light. ( Brake and blinkers continue to work w headlights on). I can't figure this out. changed all the bulbs, refreshed ground wire behind driver's tail light. Could this be the headlight switch? Which segment should light up w tail light function? Thanks in advance. Ken Link to comment Share on other sites More sharing options...
JMO413 Posted May 23, 2020 Share Posted May 23, 2020 Mine was a wire someone had spliced in at the left front running light. When I bought the truck it had an extra set of trailer lights under the taillights that they used as taillights. They were just wired to a switch. It took me about forever to find that splice. I would suggest tracing all wires in that system back to front. Gotta love Comanche wiring gremlins! Link to comment Share on other sites More sharing options...
Torq_Shep Posted May 24, 2020 Share Posted May 24, 2020 My old 89 had this problem and it was a wire that got chafed at the clutch linkage. I ran it with a seperate switch for 6 months before I figured it out. Link to comment Share on other sites More sharing options...
Pete M Posted May 24, 2020 Share Posted May 24, 2020 there's a connector at the rear near the tire that is known to have corrosion issues inside. top 2 segments should both light up with headlights. you did put in the double filament bulbs, yes? Link to comment Share on other sites More sharing options...
Alfadad Posted May 25, 2020 Author Share Posted May 25, 2020 Yes , double filaments. Ouch , the rest sounds painful. will need to be diligent Thanks all. Link to comment Share on other sites More sharing options...
