omega_rugal Posted May 20, 2020 Share Posted May 20, 2020 is posible to unweld the cowl without having to dissasemble the entire front? someone made a hole on it and i have to replace it Link to comment Share on other sites More sharing options...
Pete M Posted May 21, 2020 Share Posted May 21, 2020 wouldn't it be easier to patch it? where exactly is the hole? Link to comment Share on other sites More sharing options...
omega_rugal Posted May 21, 2020 Author Share Posted May 21, 2020 it is a big hole... Link to comment Share on other sites More sharing options...
Pete M Posted May 21, 2020 Share Posted May 21, 2020 is it in that picture? did they cut the factory hole larger to make it easier to swap out the wiper motor? Link to comment Share on other sites More sharing options...
omega_rugal Posted May 21, 2020 Author Share Posted May 21, 2020 someone made another hole on the other side... patching it may be as much work as replacing the entire thing Link to comment Share on other sites More sharing options...
AZJeff Posted May 21, 2020 Share Posted May 21, 2020 5 minutes ago, omega_rugal said: someone made another hole on the other side... patching it may be as much work as replacing the entire thing Does the photo you supplied show this "other hole", because I don't see anything that looks very large and needing to be plugged. Link to comment Share on other sites More sharing options...
omega_rugal Posted May 21, 2020 Author Share Posted May 21, 2020 2 minutes ago, AZJeff said: Does the photo you supplied show this "other hole", because I don't see anything that looks very large and needing to be plugged. the photo is from the internet Link to comment Share on other sites More sharing options...
AZJeff Posted May 21, 2020 Share Posted May 21, 2020 Just now, omega_rugal said: the photo is from the internet Ahhhh.....OK. So can you send us a pic of your cowl and the hole that needs plugging? WIth more details, I might be able to suggest a solution other than welding. Link to comment Share on other sites More sharing options...
omega_rugal Posted May 21, 2020 Author Share Posted May 21, 2020 the truck is on sale, i´ll try to contact the guy again, i don't know why is that hole there, perhaps to get rid of a rusty part but i don't want to risk buying if it can't be fixed, and if it was because of rust i should probably let it pass... Link to comment Share on other sites More sharing options...
