I want to make the doors on my Comanche be like the ones on a wrangler you can take on and off. Is there a kit? Or has someone done this? I have a 91 Comanche Pioneer
Just knock the pins out of the hinges and use bolts that are just slightly undersized, and that extend a little below the bottoms of the hinges so you can more easily tap them out.
And put disconnect plugs on the wiring from the cab to the doors.
