glennhillyer Posted May 15, 2020 Share Posted May 15, 2020 Guys, Rats ate my 89 4.0 engine wiring harness can any one point me to one I am not having any luck! Glenn Link to comment Share on other sites More sharing options...
Torq_Shep Posted May 16, 2020 Share Posted May 16, 2020 Unless you buy a used one you won't. Had the same problem with mine. Pulled it out and repaired it. Not that hard just time consuming of you are good with a soldering iron. Link to comment Share on other sites More sharing options...
Pete M Posted May 16, 2020 Share Posted May 16, 2020 there are shortcuts. these are pre-shrinkwrapped, low-temp solder units that you can use a hot air gun (with the funnel tip) to melt. there are other sizes too. https://www.ebay.com/itm/50Pcs-Waterproof-Seal-Red-Solder-Sleeve-Heat-Shrink-Tube-Wire-Crimp-Connectors/174232393059 Link to comment Share on other sites More sharing options...
pizzaman09 Posted May 16, 2020 Share Posted May 16, 2020 Likely an expensive option, but when I had an electrical fire in mine, my insurance company ended up paying to have the harness repaired by Aeromotive. They did a phenomenal job, replacing every wire in the loom that needed to be replaced. They used all of the original connectors. Link to comment Share on other sites More sharing options...
