Chriscross Posted May 7, 2020 Share Posted May 7, 2020 What is the spring perch width on a xj and a mj...in the process of converting a comanche to 4 wheel drive..using a 91 Briarwood for a donor. Also i want to spring over so need new perches ..any suggestions will be greatly appreciated. Thanks Link to comment Share on other sites More sharing options...
Chriscross Posted May 7, 2020 Author Share Posted May 7, 2020 just wanted to add that I removed the Peugeot and am installing the nv 3550 with the 231 ..will front and back drive shafts need cut down..i realized the rear will from the comanche..but what about the 91 Briarwood xj nv242..not using the 242..but it has a decent rear drive shaft Link to comment Share on other sites More sharing options...
89 MJ Posted May 7, 2020 Share Posted May 7, 2020 56 minutes ago, Chriscross said: What is the spring perch width on a xj and a mj...in the process of converting a comanche to 4 wheel drive..using a 91 Briarwood for a donor. Also i want to spring over so need new perches ..any suggestions will be greatly appreciated. Thanks The width of the perched themselves is 2.5”. I’m not sure about the width from perch to perch. Link to comment Share on other sites More sharing options...
JustEmptyEveryPocket Posted May 7, 2020 Share Posted May 7, 2020 Handy search feature: Go to Google, type in "site:comancheclub.com ******" without the quotes and your search query instead of the ******. Limits results to this site only. Makes it easy to find old threads like this one: Link to comment Share on other sites More sharing options...
mjeff87 Posted May 8, 2020 Share Posted May 8, 2020 Mopar spring perches are a recommended item. Me and a bunch of others have used them. Shop around for them, prices do vary a bit (along with shipping), but they're about $20-ish. https://www.jegs.com/i/Mopar-Performance/312/P4120074/10002/-1# Link to comment Share on other sites More sharing options...
