91 long bed comanche .. it started life as a 2wd but is now 4x4 with and external slave bell housing and ax15 . Axles it sits on now are a hp dana 44 and rear ford 9 inch .. I recently put a new motor in it and bobbed the bed .. don’t get mad because I cut the bed it has a salvage title so I actually saved it
Build Date 11/6/90
Body Model TL62
*C1 TRIM STYLE C1 - CLOTH && VINYL BENCH SEAT
-SA CHARCOAL
169 Zone 69-Phoenix
1AA U.S. Dealer Retail
4HA Special Scheduling Condition I
4XA Air Conditioning Bypass
ALA SE Decor Group
APA Monotone Paint
BAP 75 Amp Alternator
BCX Open
BGA Power Front Disc/Rear Drum Brakes
CBA Straight Back Bench Seat
CKJ Black Vinyl Floor Covering
CUM Mini Floor Console
DBB All Manual Transmissions
DDQ 5-Speed Manual Transmission
DMM 3.07 Rear Axle Ratio
DRJ 175MM Rear Axle
ERH 4.0L I6 Power Tech Engine
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEH Fixed Door Vent Glass
GRV Left Manual Mirror
GUA Open
HCD Do Not Use - See HCA
JAZ DO NOT USE - See JP, KA classes
JCA 85 MPH Primary Speedometer
K3Z STRIPE/BADGE/MOLDING/COLOR
KWX EAGLE/SUMMIT DECALS BL
LAP Shift Indicator Warning Lamp
LBC Glove Box Lamp
LMA Halogen Headlamps
MB1 Black Front Bumper
MBJ Black  Bumper
MDA Front License Plate Bracket
MFF Black Grille
MHB Bright Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMJ DRIP TROUGH MOLDINGS - TYPE I
NAF High Altitude Emissions
NBK EVAP Control System
NF5 Fuel Tank - 23 Gallon
PB3 Intense Blue  Coat
QB3 Intense Blue  Coat
RA8 Delete Radio
SBA Power Steering
SCE  Wrap Steering Wheel
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
TBC Compact Spare Tire
TBM Tire Carrier Winch
TPF P205/75R15 BSW All Season Tires
TZH Michelin Brand Tires
WJK 15X6.0 Styled Steel Wheels
WLY All Steel Wheels
XBS Pickup Box
YAA Build To U.S. Mkt. Specifications
YEP Manuf Statement of Origin
YGE 5 Additional Gallons of Gas
Z01 Rear Spring Group I
Z1A GVW/Payload Rating
Z58 Left Front Spring Group Viii
Z77 Right Front Spring Group VII
  • 8 months later...
