Torq_Shep Posted April 14, 2020 Share Posted April 14, 2020 1989 Comanche Eliminator 4.0/2wd/AW4 Very little rust but needs plenty of work. Supposedly was saved from being parted out by the PO. Has a bed light that looks original with an accompanying factory looking switch. Havent seen that before but maybe it is common? I own it. Built 03/89 Link to comment Share on other sites More sharing options...
eaglescout526 Posted April 14, 2020 Share Posted April 14, 2020 16 minutes ago, Torq_Shep said: Has a bed light that looks original with an accompanying factory looking switch If it has the cargo lamp symbol on the switch then that is factory. Yours being an 89 might tell us in the build sheet if the lamp was installed at the factory or dealer. It wasn't a common option as a lot of MJ's on here do not have it. Wish I could get you a build sheet but one of the other two members who can will get you one shortly. Glad it was saved! Link to comment Share on other sites More sharing options...
jdog Posted April 14, 2020 Share Posted April 14, 2020 build date : 3/16/89 body style: MJTS61 APAS-Monotone Paint BGAS-Power Front Disc/Rear Drum Brakes BJAS-DESCRIPTION NOT AVAILABLE BKPS-10x2.5 Rear Drum Brakes CKAS-Carpets - Floor and Cargo Area CSRS-Passenger Assist Handles DGSS-4-Speed Automatic AW4 Transmission DHAS-Lock-Up Torque Converter DMDS-3.55 Rear Axle Ratio DRJS-175MM Rear Axle GACS-Tinted Glass Windows GBBS-Tinted Windshield Glass GCBS-Front Door Tinted Glass GEHS-Fixed Door Vent Glass GNAS-Rear View Day/Night Mirror JAAS-Instrument Panel JAYS-DO NOT USE - See JP, KA classes JBDS-Instrument Panel Satin Silver Bezel JCAS-85 MPH Primary Speedometer JJAS-Cigar Lighter JKBS-MOPAR Hood Lock KLHS-DESCRIPTION NOT AVAILABLE K2BS-STRIPE/BADGE/MOLDING/COLOR K3XS-STRIPE/BADGE/MOLDING/COLOR LAFS-Seat Belt Alert-Driver Seat only LBCS-Glove Box Lamp LCJS-Overhead Ambient Surround Lighting LMAS-Halogen Headlamps LNJS-Front Fog Lamps MBJS-Black Powder Coated Front Bumper MB1S-Black Front Bumper MCAS-Rear Body Color Applique MFKS-Body Color Grille MHAS-Black Windshield Moldings MMCS-Rear Door Solid Window Insert MMGS-Belt Moldings MMKS-Lower Grille Surround-Painted Silver NAAS-Federal Emissions NBAS-Underground Calibration NBKS-EVAP Control System NDAS-Catalytic Converter NF2S1-8.5 Gallon Fuel Tank QX6S-DESCRIPTION NOT AVAILABLE SBAS-Power Steering SCGS-Leather Wrapped Steering Wheel SFAS-Standard Duty Front Shock Absorbers SGAS-Standard Duty Rear Shock Absorbers TADS-Run Flat Tires TBMS-Tire Carrier WinchWJHS15X7 Aluminum Wheels XBSS-Pickup Box XFAS-35F Protection Anti-Freeze YAAS-Build To U.S. Mkt. Specifications Z1AS-GVW/Payload Rating 1AAS-U.S. Dealer Retail162SZone 62-Houston *Q7-Cloth Low-Back Bucket Seats -SA-Charcoal ADAA-Light Group ALR-GTS Interior Package BA1P-DESCRIPTION NOT AVAILABLE BCYP-95 Amp Battery CACP-Low Back Bucket Seats CDBP-Reclining Front Seats CUFA-Full Length Floor Console DGB-All 4-Speed Automatic Transmissions DHSP-Floor Mount Automatic Shift Lever EAAC-All Engines ERB-4.0L I6 Engine GFDA-Rear Sliding Window GNBP-Driver Side Illuminated Sun Visor GRZP-Left Remote Mirror GSZP-Right Remote Control Mirror GTZA-Manual Remote Mirrors HAA-Air Conditioning JGBP-Digital Clock JHAA-Var Intermittent Windshield Wipers LAJP-Headlamps On Warning Chimes LBBP-Courtesy Lamps LBDP-Ash Tray Lamp LBEP-IP LED Ambient Light Pipe LDHP-U/Hood, Removable/Rechargeable Lamp LHDP-Headlamp Off Time Delay LPEP-Cargo Lamp MDAP-Front License Plate Bracket NHM-Speed Contro lPX6-DESCRIPTION NOT AVAILABLE RAAC-All Radio Equipped Vehicles RAFA-AM/FM Cassette Radio RCDP-4 Speakers SUAA-Tilt Steering Column TAAC-All Tires TBB-Full Size Spare Tire TRMA-P225/75R16 BSW On/Off Road Tires YGBA-1 Additional Gallons of Gas YGGA-9 Additional Gallons of Gas Z01P-Rear Spring Group I Z59P-Left Front Spring GroupIx Z79P-Right Front Spring Group IX 5ASA-Dodge City Tracking 5KRA-Midland Corporation Link to comment Share on other sites More sharing options...
jdog Posted April 14, 2020 Share Posted April 14, 2020 5 minutes ago, jdog said: LPEP-Cargo Lamp @eaglescout526 looks like its a factory installed light Link to comment Share on other sites More sharing options...
eaglescout526 Posted April 14, 2020 Share Posted April 14, 2020 Indeed it does. Thanks jdog! Link to comment Share on other sites More sharing options...
jdog Posted April 1, 2021 Share Posted April 1, 2021 Selling Dealer: DEMONTROND AUTO COUNTRY INC - Conroe, TX Link to comment Share on other sites More sharing options...
