87MJ_ Posted April 14, 2020 Share Posted April 14, 2020 Does anyone know how to attach an XJ bumper to an MJ? Link to comment Share on other sites More sharing options...
Eagle Posted April 14, 2020 Share Posted April 14, 2020 You will have to make a custom bracket. Where are you going to mount the license plate and light(s)? Link to comment Share on other sites More sharing options...
89 MJ Posted April 14, 2020 Share Posted April 14, 2020 I know @dasbulliwagen put an XJ rear bumper on his. Not sure how though. Link to comment Share on other sites More sharing options...
MontanaManche Posted April 15, 2020 Share Posted April 15, 2020 making some custom brackets is probably your best bet. could make some templates out of cardboard and cut some steel or something similar. If your don't want to mess with fabrication you could talk to a fab shop and they could make some brackets, expensive though. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted April 19, 2020 Share Posted April 19, 2020 I'm sorry, I didn't see the alert sooner. I started by just holding the XJ bumper up on the rear of my Comanche. I noticed that the flat mount plates of the bumper would be good at about the same level as the rear edge of the bed. So I started with mounting plates in the correct location on the back edge of the bed floor. Then I added supports off the front of the plate to existing mount holes in the the uniframe. Then all I had to do was trim the bumper end caps to fit around the bed corners. You'll then need to figure out a plate mount for it since you'll no longer have a place to put it. I've been through a couple different ones on mine, and I'm currently building a third and hopefully final one for my plate, most likely integrated with my recently added trailer hitch. Here are a few pictures. You can also see them in my build thread, Comanche Limited. Link to comment Share on other sites More sharing options...
NComanche Posted April 22, 2020 Share Posted April 22, 2020 Are these available to buy? Link to comment Share on other sites More sharing options...
