1J7FT26P7ML551108
natander2ksometime
1991 Jeep Comanche SWB
Picture from date of purchase (July 18, 2017, Mesa, AZ):
Current setup:
1998 Jeep 4.0, AW4 Auto, NP242, Dana 30 and Chrysler 8.25 with 4.88 gears and rear Aussie locker, SWB
Originally a 2WD 4 cylinder with manual transmission (sold at Galloway Motors of Tucson, AZ)
Build date: 11-90
Current Location: Denver, CO
Current status: Well driving multi-purpose machine, but also an ongoing project
Notes:
Full 1998 swap, Dodge Dakota 22 gallon gas tank, XJ bucket seats (still have the factory bench), Bushwacker Flat Fender Flares for an XJ, Iron Rock Offroad 3 link in the front, ~5" coils, IRO double shear track bar, Currie steering, SOA with 2WD leaves in the back, 315/70/17 KO2's on JK wheels with 1.5" adapters, Gibson header, K Suspension injectors, Spectre Cowl Air Intake, transfer case clocked 10 degrees to accommodate IRO skid plate, The Flop Shop front bumper with Warn VR8000 winch, Dirtbound rear bumper with hitch, JCR rock sliders, unknown brand topper (came off another MJ), custom built sleeping platform in bed (fits spare parts, driveshafts, axle shafts, spare tie rod and drag link, 35" spare, tools, cooler, and food camping box all underneath)
Build Date 11/6/90
Body Model TL61
*C1 TRIM STYLE C1 - CLOTH && VINYL BENCH SEAT
-SA CHARCOAL
169 Zone 69-Phoenix
1AA U.S. Dealer Retail
4XA Air Conditioning Bypass
ALA   Decor Group
APA Monotone Paint
BAP 75 Amp Alternator
BCX Open
BGA Power Front Disc/Rear Drum Brakes
CBA Straight Back Bench Seat
CKJ Black Vinyl Floor Covering
CUM Mini Floor Console
DBB All Manual Transmissions
DDQ 5-Speed Manual Transmission
DMF 4.10 Rear Axle Ratio
DRJ 175MM Rear Axle
EPE Engine - 2.5L Power Tech I-4 Cyl.
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEH Fixed Door Vent Glass
GRV Left Manual Mirror
GUA Open
HCD Do Not Use - See HCA
JAZ DO NOT USE - See JP, KA classes
JCA 85 MPH Primary Speedometer
K3Z STRIPE/BADGE/MOLDING/COLOR
KDN
KWS STRIPE/BADGE/MOLDING/COLOR
LAP Shift Indicator Warning Lamp
LBC Glove Box Lamp
LMA Halogen Headlamps
MB1 Black Front Bumper
MDA Front License Plate Bracket
MFF Black Grille
MHB Bright Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMJ DRIP TROUGH MOLDINGS - TYPE I
NAA Federal Emissions
NBK EVAP Control System
NF2 18.5 Gallon Fuel Tank
PW7 Bright White Clear Coat
QW7 Bright White Clear Coat
RA8 Delete Radio
SBA Power Steering
SCE  Wrap Steering Wheel
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
TBC Compact Spare Tire
TBM Tire Carrier Winch
TNC P195/65R15 BSW AS Touring Tires
TZH Michelin Brand Tires
WJK 15X6.0 Styled Steel Wheels
WLY All Steel Wheels
XBS Pickup Box
YAA Build To U.S. Mkt. Specifications
YGE 5 Additional Gallons of Gas
Z01 Rear Spring Group I
Z1A GVW/Payload Rating
Z56 Left Front Spring Group Vi
  On 4/7/2020 at 11:57 PM, JMO413 said:
Build Date 11/6/90
Body Model TL61
-SA CHARCOAL
169 Zone 69-Phoenix
ALA   Decor Group
APA Monotone Paint
BCX Open
DRJ 175MM Rear Axle
GUA Open
KDN
LBC Glove Box Lamp
MFF Black Grille
MMG Belt Moldings
RA8 Delete Radio
SBA Power Steering
XBS Pickup Box
Expand
Thank you for that! Because I purchased the Jeep post-97+ swap, I had no idea how it came from the factory.  It's a much different Jeep now!
  On 4/8/2020 at 4:46 PM, JMO413 said:
No problem glad I could be of help. That is a very nice looking truck you've built there. How about a few more pictures in a build thread.:brows:
Expand
Thank you very much! I actually just updated my build thread yesterday!  I promise I'll try to be better about updating it haha
  • 9 months later...
