[RENIX] AEM wide band 02, MegaSquirt ecu
starting to get back onto my comanche rebuild.
that being said i need to decide what ecu and wide band i will use to tune the 4.7L stroker (Robert Bryce's original homebuilt 4.5L stroker from the 90's)
doing some research, i have found the AEM and MS to be the most suitable choice for my application.
though, never doing standalone before, i am competent and just need some input on people who have went standalone,
for why they have went the route they have chosen.
i have access locally to a dyno/tuner so tuning won't be an issue.
as title states, this a a renix (93 HO block, with renix sensors) jeep.
Thanks
I was also between megasquirt and AEM.  Ultimately got an AEM because I got it for super cheap.  I have yet to install or do anything with it but those are definitely the two choices for a Jeep from everything I have read.
I would say you should talk to the tuner and see which system they have used or are more comfortable with, they may even outright say they won't work on one or the other so they may make the decision for you.
this.  :L:
