87 comanche 4.0l.
New to this so please bear with me.washed engine to change valve cover gasket,  I had unplugged battery and let set more than 24 hrs. Tried to crank and started getting backfire that blowed out map sensor vacuum line from back of T.Body. It has spark and is getting fuel, was driving it before replacing gasket,  replaced CPS, can't find any info on why it blows vacuum line, it will not try to run only blowback, please help
Welcome to the forum.
Upper right hand of screen. Click on Username. Click on Account Settings. Find and click on Signature. Add vehicle info here (YR ENG TRANS etc etc) and save. This helps everyone. Information will be available every time you post.
