ThorMacLeod Posted March 11, 2020 Share Posted March 11, 2020 1990 Comanche Eliminator 4x4 4.0L Engine, AW4 Transmission, NP231 TC, D30 front axle, D35 rear axle, short bed. White exterior, gray interior, cloth bucket seats, floor shift. Build date I'm not sure about since the driver's door is not the original. Located in Fairbanks Alaska Acquired from first owner in 1996, very much still on the road. The truck has a front skid plate ahead of the steering / suspension and a skid plate over the fuel tank, might be dealer options. Class 3 rear, frame mounted hitch. Tow and recovery hooks mounted at the front frame mounts below the bumper.Original fog lights replaced with KC long range lights when they crumbled off the otherwise intact front bumper. Shell over the bed is an 'Aztec model with a 'Vacation Village, SLC UT' dealer sticker. Also, the front CAD setup has had been converted to a solid XJ/YJ set with a CAD eliminator plate, done after the bushing in the driver's side of the CAD failed and the shift collar would travel too far to reliably engage both halves of the axle. Link to comment Share on other sites More sharing options...
eaglescout526 Posted March 11, 2020 Share Posted March 11, 2020 *Q7 Cloth Low-Back Bucket Seats -SA Charcoal 174 Zone 74-Denver 1AA U.S. Dealer Retail 5KP PLY GEM Industries ADH Heavy Duty Electrical Group ALP Proactive Safety Group APA Monotone Paint ARM Radio AM/FM Cassette BA1 100 AMP ALTERNATOR BCY 475 AMP BATTERY BGA Power Front Disc/Rear Drum Brakes CAC Low Back Bucket Seats CDB Reclining Front Seats CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles CUM Mini Floor Console DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHN Command-Trac Part Time 4WD System DHS Floor Mount Automatic Shift Lever DJH 230MM Front Axle DMD 3.55 Rear Axle Ratio DRJ 175MM Rear Axle ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GFD Rear Sliding Window GNA Rear View Day/Night Mirror GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HCD Do Not Use - See HCA JAY DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer JGB Digital Clock JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K2B STRIPE/BADGE/MOLDING/COLOR K3W STRIPE/BADGE/MOLDING/COLOR KLH LBC Glove Box Lamp LCJ DOME/READING LAMP B-PILLAR LMA Halogen Headlamps LNJ Front Fog Lamps MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MCA Rear Body Color Applique MDA Front License Plate Bracket MFK Body Color Grille MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAF High Altitude Emissions NBK EVAP Control System NF2 18.5 Gallon Fuel Tank PW7 Bright White Clear Coat QW7 Bright White Clear Coat RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Steering SCG Leather Wrapped Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers SUA Tilt Steering Column TAA All Tires TBB Full Size Spare Tire TBM Tire Carrier Winch TRN P225/75R15 OWL Wrangler AT Tires WJH 15X7 Aluminum Wheels WLZ All Aluminum Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z66 Left Front Group XV Z85 Right Front Spring Group XIV Build date 10/31/89. Ooooo spooky MJ. Body code JL61 Link to comment Share on other sites More sharing options...
ThorMacLeod Posted March 11, 2020 Author Share Posted March 11, 2020 1 hour ago, eaglescout526 said: Build date 10/31/89. Ooooo spooky MJ. Body code JL61 LOL, that's awesome! Thanks for all the info! Link to comment Share on other sites More sharing options...
eaglescout526 Posted March 11, 2020 Share Posted March 11, 2020 No problem! Link to comment Share on other sites More sharing options...
jdog Posted February 10, 2021 Share Posted February 10, 2021 Selling Dealer: US AIR FORCE Warner Robins, GA Link to comment Share on other sites More sharing options...
