1990 Comanche Eliminator 4x4
4.0L Engine, AW4 Transmission, NP231 TC, D30 front axle, D35 rear axle, short bed.
White exterior, gray interior, cloth bucket seats, floor shift.
Build date I'm not sure about since the driver's door is not the original.
Located in Fairbanks Alaska
Acquired from first owner in 1996, very much still on the road.
The truck has a front skid plate ahead of the steering / suspension and a skid plate over the fuel tank, might be dealer options. Class 3 rear, frame mounted hitch. Tow and recovery hooks mounted at the front frame mounts below the bumper.Original fog lights replaced with KC long range lights when they crumbled off the otherwise intact front bumper. Shell over the bed is an 'Aztec model with a 'Vacation Village, SLC UT' dealer sticker. Also, the front CAD setup has had been converted to a solid XJ/YJ set with a CAD eliminator plate, done after the bushing in the driver's side of the CAD failed and the shift collar would travel too far to reliably engage both halves of the axle.
