Like the title says, my turn signal stalk is super floppy/loose.  It still works fine in all functions but I can pretty much make a circle without it grabbing any of the functions like high beams or turn signal. Is this because of the main switch inside the steering wheel?  Also, if I do replace that what else should I do while I'm in there. Thanks.
I just ordered a new stalk because mine is all cracked and ugly. A new turn switch is only 30 bucks for an acdelco so i might just order it and since I'm going in there i might as well replace it.  The wiper switch on the other hand is 150....so that will stay put.
Welp I decided that if I'm opening it up I'm replacing it all. 100 bucks for high beam switch, turn signal switch, new cam, stalk, tumbler, and ignition switch. Pretty much a freshening up minus wiper switch
