Undy MJ Posted February 11, 2020 Posted February 11, 2020 I have an 86' Comanche with 119,000 miles on it. It has the original 2.8 in it. It is an automatic with the floor shifter. Almost every time I stop and then give it gas it cuts off. It seems to slam in to gear a little. I have to put it in neutral, give it some gas, then pull it in gear to keep it running. Any help or advice would be greatly appreciated. Thanks. Robert Underwood. Roanoke, Va.
Undy MJ Posted February 11, 2020 Author Posted February 11, 2020 7 minutes ago, Pete M said: fluid level normal? meaning FUEL ?
Pete M Posted February 11, 2020 Posted February 11, 2020 sorry, I meant the transmission fluid level.
omega_rugal Posted February 11, 2020 Posted February 11, 2020 check the engine, it´s stalling due lack of power
omega_rugal Posted February 11, 2020 Posted February 11, 2020 ok to clarify, it´s an engine problem, not a transmision problem...
Undy MJ Posted February 12, 2020 Author Posted February 12, 2020 2 hours ago, omega_rugal said: ok to clarify, it´s an engine problem, not a transmision problem...
Undy MJ Posted February 12, 2020 Author Posted February 12, 2020 possibly timing...or something worse ??
omega_rugal Posted February 12, 2020 Posted February 12, 2020 1 minute ago, Robert U said: possibly timing...or something worse ?? the old V6s were carbed, running too lean, vacuum leak, or bad timing, anything that causes loss of power
Undy MJ Posted June 19, 2023 Author Posted June 19, 2023 On 2/11/2020 at 2:56 PM, Robert U said: meaning FUEL ? YES
